ASA failover question
Apr 2nd, 2009
I have read all the docs regarding ASA failover using the sla monitor command. The doc indicates that the failover occurs between two interfaces (eth0/0 and eth0/1). so my question is that if i have one copper hand off and that goes into eth0/0 and have two vlans on that interface. can i have the same failover using the vlan with sla monitor? or does that just work with physical interfaces?
Anonymous (not verified) Thu, 04/09/2009 - 12:22
Both active and standby ASA's should have the same configuration which applies to VLAN also.
