7937 questions
Answered Question
Apr 2nd, 2009
Looking at the datasheet for this piece I see that support for CME "will be supported in the future". Is the future now? Will this work on a UC520 system running V4.2? Also, does the mic kit bring one mic or two? The picture shows two mics but the description of the actual kit is not clear.
Diego
Correct Answer by rob.huffman about 7 years 9 months ago
Hi Diego,
Just to add a note to the great tips from Nick (+5 points here Nick :)
The Mic Kit does come with 2 external Mic's. I have one sitting in front of me right now (pretty cool looking little guys!).
Cheers!
Rob
Overall Rating: 4.3 (3 ratings)
Nicholas Matthews Thu, 04/02/2009 - 13:10
Hi Diego,
You're probably looking at an older version.
We implemented some new commands in 12.4(15)XZ that allow for certain templates to be added that we used for the 7937.
On my 12.4(20)T2 router in the lab, the type command shows the 7937. Additionally, you can check the command reference on the 'type' command, it will tell you exactly where it went in.
But to be short, it's supported after 20T.
-nick
DIEGO ALONSO Thu, 04/02/2009 - 18:49
Just any image after 20T? What about the CME version or the fact that I am using a UC500 based box?
Diego
Nicholas Matthews Thu, 04/02/2009 - 21:54
Hi Diego,
CME 7.0 is the CME version, which is 20T. CME version = IOS version, there's no way to change one without the other.
UC500 supports 12.4(11)XW code and any code 20T or later.
-nick
Correct Answer
rob.huffman Thu, 04/02/2009 - 14:13
Hi Diego,
Cheers!
Rob
