IP Communicator
Apr 2nd, 2009
I have installe the softphone on an end users laptop. When I test it, the dial tone is choppy, and when I listen to the voicemail it sounds as though it is in slow motion. Never had this probem before.
tim.giles Thu, 04/09/2009 - 03:34
Probably the laptop is the problem rather than anything else?
Have you checked the CPU, memory etc. Use PerfMon to view the output..
pamela.wheaton Thu, 04/09/2009 - 03:38
I did figure out the probem, I just needed to install a newer version of the IP communicator, but thanks for the response.
