04-02-2009 02:01 PM - edited 03-14-2019 03:54 AM
IPCC Ent 6X with IPIVR 4X. Got an outbound campaign setup to dial out and play canned messages and seems to be working. The only issue I cant figure out is that when the call connects, there is a long silence and short music before the script plays in IPIVR. Is there a delay timer that can be tweaked to eliminate this?
Solved! Go to Solution.
04-02-2009 03:41 PM
The music is likely coming from the hold audio source on the Dialer ports. In Call Mangager, set the hold audio source for the dialer ports to silence.
For slow transfer times this document may be helpful: http://www.cisco.com/en/US/products/sw/custcosw/ps1844/products_tech_note09186a00805b6e23.shtml
Often long transfer times are related to answering machine detection. You can look up recommended answering machine detection settings in the latest outbound user guides.
04-02-2009 03:41 PM
