Bridging 877
Apr 2nd, 2009
I have... 2 public IP 's.
an adsl modem -> 877 -> a managed vpn appliance connected via eth.
I have given the atm0 one of the addresses and the vpn appliance the other.
I tried to set up pure bridging following..
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a816.shtml
and am running into problems. When I get to the point of assigning the bridge-group to the f0, I get an error message..
fastethernet0 does not support bridging.
I then assigned vlan1 to the bridge-group successfully. Seems OK to me, but the 877, and the connected vpn appliance cannot ping each other in either direction.
any ideas appreciated.
Giuseppe Larosa Thu, 04/02/2009 - 14:26
  • Hall of Fame,
    Founding Member
Hello Mark,
the fas ports are seen as switch ports you need to declare association to bridge-group 1 under int vlan 1
int vlan1
no ip address
bridge-group 1
being fas0 in vlan 1 with default config you achieve the desired result
see bridging over vlans
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html#wp999748
Edit:
I see you have already discovered this however follow the document you may be missing some global config command about irb or crb.
Hope to help
Giuseppe
carverwd Tue, 11/17/2015 - 11:06
I realize this was a super long time ago, but I've been struggling with this one as well.  Thanks Giuseppe!  Worked instantaneously.
I guess I just figured that the sub interface would tie them together...but that wasn't enough.  I had to have a interface vlan <#> then add that to the bridge group.
