Cookie question
Answered Question
Apr 2nd, 2009
folks
I have cisco ACE blade and I have 2 questions
2. Size of HTTP header/cookie the LB can accept to maintain the stickiness, is there any size limitation for cookie size?
3. Any fallback for stickiness if it doesn't support large header/cookie size
Correct Answer by Syed Iftekhar Ahmed about 8 years 3 months ago
By Default ACE can parse header of 4K Bytes . This default value can be changed using a http type parameter map.
The maximum an ACE can parse is 64K.
Following is an example to change it to maximum.
parameter-map type http APP1_PARAM_MAP
set header-maxparse-length 65535
then apply this parameter-map to the policy
policy-map multi-match xyz
class APP1
loadbalance vip inservice
loadbalance policy xxx
loadbalance vip icmp-reply
appl-parameter http advanced-options APP1_PARAM_MAP
Syed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Thu, 04/02/2009 - 14:45
  • Blue, 1500 points or more
class APP1
Syed
kirit_patel Thu, 04/02/2009 - 18:03
syed
thanks
If incase the http header exceeds 4kbytes what will happen to the persistence? Does it fall back to sticky by IP?
Is there a way we can setup session using ASP.NET session ID
Syed Iftekhar Ahmed Thu, 04/02/2009 - 18:25
No
If a cookie, HTTP header, or URL
exceeds the default value, the ACE drops the packet and sends a RST
(reset) to the client browser.
This behavior can be changed using "length-exceed continue", however
I dont recommend this.
Its better to increase the Header parse length to the header length expected by your app.
Syed
kirit_patel Thu, 04/02/2009 - 18:40
syed thanks
The client is asking for following and asking if it can be configured
1. Verify that the load balancer (LB) is configured to load balance jpeg files.
2. Review the configuration of the LB; the load balancer should be configured to balance requests based on the ASP.Net session id of the request.
3. Define the maximum size of HTTP header the LB is configured to handle.
4. Define the LB fallback configuration if the HTTP header size is exceeded.
Here is my current config:
serverfarm host xxx.x.xxx.xx-443
probe TCP_443
rserver nj09app515 443
inservice
rserver nj09app517
inservice
serverfarm host xxx.x.xxx.xx-80
probe TCP_NEW_80
rserver nj09app515 80
inservice
rserver nj09app517 80
inservice
sticky http-cookie INF_COOKIE xxx.x.xxx.xx-80_STICKY
cookie insert
timeout 30
replicate sticky
serverfarm xxx.x.xxx.xx-80
sticky ip-netmask 255.255.255.0 address source xxx.x.xxx.xx-443_STICKYIP
replicate sticky
serverfarm 204.8.132.74-443
class-map match-all xxx.x.xxx-443_CLASS
2 match virtual-address xxx.x.xxx.xx tcp eq https class-map match-all xxx.x.xxx.xx-80_CLASS
2 match virtual-address xxx.x.xxx.xx tcp eq www
Syed Iftekhar Ahmed Thu, 04/02/2009 - 23:45
1. Its Do-able
2. Use a sniffer check the static portion of Jsession-ID (usually its 10 bytes from offset 53). Following is the config for offset53,length10
sticky http-cookie JSESSIONID stitcky1
cookie offset 53 length 10
serverfarm APP1-SF
policy-map type loadbalance first-match APP1-POLICY
class class-default
sticky-serverfarm stitcky1
3. As I mentioned earlier, use sniffer check the size of the header for regular traffic. If its more than the default ACE value then adjust it using
4. By default packet is dropped & RST is sent by ACE. If you want to change this behavior then use "length-exceed continue" to allow such packets through ACE.
Syed
