Visioconference : Cisco 7985 with Tandberg
Apr 2nd, 2009
I have CCM 7,and 7985 endpoint registered as SCCP endpoint.Our Need, to communicate with Tandberg endpoint that can be accessed via IP.Is there any requirement to use Gatekeeper and register both endpoints to it ?
DOUG DAVIDSON Mon, 04/13/2009 - 14:24
Depending on the model Tandberg you are using, you might be able to upgrade it to SCCP. That is what we have done and it works great.
HTH,
Doug
