Warning message
Error Message on AS5350
Apr 2nd, 2009
The attached file was from cisco output interpreter tool. As a work around, I was trying to load a new IOS image on flash, but it shows "not enough space available" I issue the command show flash (see details below)
show flash
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .D image EC7D4758 E025E0 22 14165344 Dec 2 2006 10:51:36 +00:00 c5350-is-mz.123-6e.bin
2 .D config 417C308D E04260 2 7165 Mar 28 2009 01:15:55 +00:00 no
3 .D config 7684A73B E05F2C 6 7241 Mar 30 2009 23:31:00 +00:00 staryt
4 .D crashinfo C7DB03D6 E36528 25 198011 Apr 2 2009 06:44:35 +00:00 crashinfo_20090402-064435
5 .D crashinfo 2ED647F5 E678C8 25 201504 Apr 2 2009 06:45:29 +00:00 crashinfo_20090402-064529
6 .D crashinfo 634D838E E989B4 25 200811 Apr 2 2009 07:17:06 +00:00 crashinfo_20090402-071706
7 .D crashinfo F4594C04 ECB288 25 206930 Apr 2 2009 07:24:57 +00:00 crashinfo_20090402-072457
8 .D crashinfo AEEF5164 EFC378 25 200813 Apr 2 2009 08:29:56 +00:00 crashinfo_20090402-082956
9 .D crashinfo 1A60AEE6 EFFFE0 25 15335 Apr 2 2009 08:34:02 +00:00 crashinfo_20090402-083402
32 bytes available (15204320 bytes used)
GACI-WiFi-E1R2#
I tried remove everything on it, but it said file not found. Can someone help me out on this problem, any suggestions ?
Nicholas Matthews Thu, 04/02/2009 - 22:39
  • Red, 2250 points or more
What exactly did you put in the IOS output interpreter? You would need to copy these files off of flash and insert them, as well as with a full 'show version' for it to do anything.
other than that, you can use the 'squeeze' function to clear deleted space off the flash drive.
-nick
