How to clear status "deceased" ephone in CME?
Apr 2nd, 2009
I started configuring an ephone to one identifier and decided to change to use another. So initially I associated the mac of the phone with ephone-14. The phone registered and then I decided I wanted to change the mac to another ephone (say ephone 24). Although I had turned off physical phone - CME would not let me associate the MAC with a new ephone thinking ephone 14 was still in existance even though I had deleted it from the running and startup config. "show ephone" revealed that CME was still seeing ephone 14 albeit being in "DECEASED" mode. How do you clear this entry without rebooting the entire CME router?
ephone-14 Mac:0024.14B3.XYXA TCP socket:[-1] activeLine:0 DECEASED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:1 caps:9
IP: 50194 7965 keepalive 1 max_line 6
Overall Rating: 5 (1 ratings)
Nicholas Matthews Thu, 04/02/2009 - 21:56
You can try this:
no auto-reg-ephone
no ephone
mmedwid Thu, 04/02/2009 - 22:17
I may not get a chance to test this out before PTO. But that definitely sounds like the right track. Thanks Nick.
