Failed to http firewall (pdm) page
Apr 2nd, 2009
Dear sir,
We have an existing 5 ip address that able to http into the pdm page. We try to add in 4 new ip address for http into the pdm page as well. Hereby we applies below steps 1 & 2 to achieve the objective.We try to use 1-4 pc that used the new ip address ,, & to http into the pdm but we not able to login as shown in attachment "can't login.jpg" and prompt up error message as shown below --Java Error--.
Please advise any idea to solve this issue. Thank you very much and appreciation.
Step 1
To identify the IP addresses from which the FWSM accepts HTTPS connections, enter the following command for each address or subnet:
hostname(config)# http source_IP_address mask source_interface
Step 2
To enable the HTTPS server, enter the following command:
hostname(config)# http server enable
For example, to enable the HTTPS server and let a host on the inside interface with an address of access ASDM, enter the following commands:
hostname(config)# http inside
To allow all users on the network to access ASDM on the inside interface, enter the following command:
--Java Error--
Java Plug-in 1.6.0_12
Using JRE version 1.6.0_12 Java HotSpot(TM) Client VM
User home directory = C:\Users\user1
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to <n>
load: class not found.
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$ Source)
at Source)
Caused by: open HTTP connection failed:
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$ Source)
at Method)
... 7 more
Exception: java.lang.ClassNotFoundException:
