Transparent ASA in middle of 802.1q trunk
Apr 2nd, 2009
Hi Everyone,
I am hoping someone can provide some advice regarding an ASA in transparent mode sitting in the middle of a .1q trunk.
Scenario is two switches (one routing) has multiple VLAN's setup and then a trunk down to a L2 switch which then has all the end user devices hanging off it. We have a requirement to put an ASA in the middle in transparent mode (and also do IPS) but I cannot for the life of me seem to find a configuration that supports this method.
Any advice/pointers/hints/anything would be most appreciated.
srue Fri, 04/03/2009 - 05:25
You can't configure more than 2 interfaces (or subinterfaces) in transparent mode - ie, no trunking.
If you're looking to control traffic between subnets/vlans you will have to place your ASA differently and possibly do some minor network reconfiguration.
