7200VXR with NPE-G1 crash
Apr 2nd, 2009
Hi all,
I have had a Cisco 7206VXR with NPE-G1 router running 12.4(22)T AdvIP Serv. crash twice in the last week. My syslog indicates a memory allocation failure / no memory error. The router runs a full BGP table. I was hoping somebody could point out quickly if there was a known issue with this configuration or not. I am investigating Bug reports and using output interpreter as well as egaging TAC but if anyone can offer some rapid thoughts, i would appreciate it. Many thanks in advance.
1 vote
Giuseppe Larosa Fri, 04/03/2009 - 00:20
Hello Craig,
the router should be fine for this job.
is it learning a single full table from a single ISP ?
Do you see free memory reducing over time (some process not releasing memory) ?
This could lead to a a software bug.
or it might be hardware related there is any indication in the crash info about the pointers values at the moment of crash?
Hope to help
Giuseppe
craig.potter Fri, 04/03/2009 - 03:24
Thanks for your response. My error seems to revolve around memory fragmentation which causes an out of memory issue and stops everything. I have pasted the syslog messages below for reference. I cannot find any known bugs so it may be new. I will be watching the memory over the next 24 hours to see if I can find why or what is happening to the memory.
Apr 1 09:57:11 203.41.44.1 311: .Mar 31 22:57:10.217: %SYS-2-MALLOCFAIL: Memory allocation of 780 bytes failed from 0x60243A38, alignment 32
Apr 1 09:57:11 203.41.44.1 312: Pool: I/O Free: 50800 Cause: Memory fragmentation
Apr 1 09:57:11 203.41.44.1 313: Alternate Pool: None Free: 0 Cause: No Alternate pool
Apr 1 09:57:11 203.41.44.1 314: -Process= "Pool Manager", ipl= 0, pid= 6, -Traceback= 0x612F58E8 0x6000A944 0x60010ABC 0x60011324 0x60243A40 0x60021790 0x60021A2C
Apr 3 14:34:05 203.xx.xx.x 400: Apr 3 03:34:04.386: %SYS-2-MALLOCFAIL: Memory allocation of 920 bytes failed from 0x602439EC, alignment 0
Apr 3 14:34:05 203.xx.xx.x 401: Pool: Processor Free: 309184 Cause: Memory fragmentation
Apr 3 14:34:05 203.xx.xx.x 402: Alternate Pool: None Free: 0 Cause: No Alternate pool
Apr 3 14:34:05 203.xx.xx.x 403: -Process= "ADJ resolve process", ipl= 0, pid= 82, -Traceback= 0x612F58E8 0x6000A944 0x60010ABC 0x600111F0 0x63832F7C 0x602439F4 0x60244080 0x60244E10 0x61A281B4 0x61A28918 0x61A28EFC 0x61A290A8 0x61A2A800 0x638425B8 0x6171680C 0x616849D0
Apr 3 14:34:05 203.xx.xx.x 404: Apr 3 03:34:04.946: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for CCE dp subbloc. No memory available -Process= "Chunk Manager", ipl= 3, pid= 1, -Traceback= 0x612F58E8 0x6001D1B0
Apr 3 14:34:31 203.xx.xx.x 406: Apr 3 03:34:28.702: %BGP-5-ADJCHANGE: neighbor 139.x.x.x Down No memory
Apr 3 14:34:31 203.xx.xx.x 407: Apr 3 03:34:28.738: %BGP-5-ADJCHANGE: neighbor 203.x.x.x Down No memory
Apr 3 14:34:31 203.xx.xx.x 408: Apr 3 03:34:28.738: %BGP-3-NOTIFICATION: sent to neighbor 203.62.252.39 3/1 (update malformed) 0 bytes
Apr 3 14:34:58 203.xx.xx.x 409: Apr 3 03:34:57.615: %BGP-5-ADJCHANGE: neighbor 139.x.x.x Up
Apr 3 14:35:12 203.xx.xx.x 410: Apr 3 03:35:11.363: %BGP-5-ADJCHANGE: neighbor 203.x.x.x Up
Apr 3 14:36:30 203.xx.xx.x 411: Apr 3 03:36:29.871: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed from 0x6001DCDC, alignment 0
Apr 3 14:36:30 203.xx.xx.x 412: Pool: Processor Free: 872832 Cause: Memory fragmentation
Apr 3 14:36:30 203.xx.xx.x 413: Alternate Pool: None Free: 0 Cause: No Alternate pool
Apr 3 14:36:30 203.xx.xx.x 414: -Process= "BGP Router", ipl= 0, pid= 289, -Traceback= 0x612F58E8 0x6000A944 0x60010ABC 0x60011158 0x6001DCE4 0x6001EDA0 0x61C25E90 0x61C26294 0x61C31658 0x60EA67F8 0x60EA71C0 0x60EA83E0 0x63806678 0x60EA8498 0x60E7B390 0x60E7D15C
Apr 3 14:36:30 203.xx.xx.x 415: Apr 3 03:36:29.979: %COMMON_FIB-3-NOMEM: Memory allocation failure for prefix in IPv4 CEF [0x6166F9B8] (fatal) (76 subsequent failures).
Apr 3 14:36:35 203.xx.xx.x 416: Apr 3 03:36:29.979: %COMMON_FIB-4-DISABLING: IPv4 CEF is being disabled due to a fatal error.
Apr 3 14:36:35 203.xx.xx.x 417: Apr 3 03:36:34.663: %BGP-5-ADJCHANGE: neighbor 139.x.x.x Down No memory
Apr 3 14:36:35 203.xx.xx.x 418: Apr 3 03:36:34.695: %BGP-5-ADJCHANGE: neighbor 203.x.x.x Down No memory
Apr 3 14:36:36 203.xx.xx.x 419: Apr 3 03:36:35.303: %BGP-3-NOTIFICATION: sent to neighbor 203.x.x.x 3/1 (update malformed) 0 bytes
Thanks again.
Craig
