Inbound Call on E1 R2
worldcalltel
I am trying to make an inbound call from Telco-->AS5350-->SIP Server and below are the logs on debug csm voice.
Apr 3 05:51:42.891: VDEV_ALLOCATE: 2/10 is allocated
Apr 3 05:51:42.891: 1.starting digit collect: reset dnis_collected & fap_notify
Apr 3 05:51:42.895: CSM_RX_CAS_EVENT_FROM_NEAT:(0002): EVENT_CALL_DIAL_IN at slot 2, port 10
Apr 3 05:51:42.895: CSM_PROC_IDLE: CSM_EVENT_START_DIGIT_COLLECT at slot 2, port 10
Apr 3 05:51:42.895: CSM DSPLIB(2/10/csm_flags=0x54): np_dsplib_prepare_modem
Apr 3 05:51:42.895: csm_connect_pri_vdev: TS allocated at bp_stream 0, bp_Ch 10, vdev_common 0x6375139C 2/10
Apr 3 05:51:42.923: CSM DSPLIB(2/10):DSPLIB_SIG_INIT: Signaling session transition to IDLE
Apr 3 05:51:42.935: CSM DSPLIB(2/10):DSPLIB_SIG_WAIT_ACTIVE: Signaling session transition to ACTIVE
Apr 3 05:51:42.935: CSM DSPLIB(2/10): Modem went offhook
Apr 3 05:51:42.935: CSM_PROC_IC1_COLLECT_ADDR_INFO: CSM_EVENT_MODEM_OFFHOOK (DNIS=, ANI=) at slot 2, port 10
Apr 3 05:51:42.935: CSM to NEAT:(0002) EVENT_CHANNEL_LOCK for slot 1 ctlr 0 chan 2
Apr 3 05:51:42.935: CSM to NEAT:(0002) EVENT_VOICE_ANS for slot 1 ctlr 0 chan 2
Apr 3 05:51:42.991: CSM_RX_CAS_EVENT_FROM_NEAT:(0002): EVENT_START_RX_TONE at slot 2, port 10
Apr 3 05:51:44.059: CSM_RX_CAS_EVENT_FROM_NEAT:(0002): EVENT_CALL_IDLE at slot 2, port 10 cause 200
Apr 3 05:51:44.059: CSM_PROC_IC1_COLLECT_ADDR_INFO: CSM_EVENT_DSX0_DISCONNECTED (DNIS=, ANI=) at slot 2, port 10
Apr 3 05:51:44.059: CSM DSPLIB(2/10): np_dsplib_call_hangup reason 0
Apr 3 05:51:44.059: CSM(2/10): Enter csm_enter_disconnecting_state
Apr 3 05:51:44.067: CSM DSPLIB(2/10):DSPLIB_IDLE: Signaling session transition to FLUSHING
Apr 3 05:51:44.067: CSM DSPLIB(2/10):DSPLIB_IDLE: Signaling session transition to IDLE
Apr 3 05:51:44.067: CSM DSPLIB(2/10): Modem went onhook
Apr 3 05:51:44.067: CSM_PROC_IC8_OC8_DISCONNECTING: CSM_EVENT_MODEM_ONHOOK at slot 2, port 10
Apr 3 05:51:44.067: CSM(2/10): Enter csm_enter_idle_state
Apr 3 05:51:44.067: VDEV_DEALLOCATE: slot 2, port 10 is deallocated
Apr 3 05:51:44.079: CSM DSPLIB(2/10):DSPLIB_IDLE: Modem session transition to IDLE
Configuration
controller E1 1/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country philippines
category 7
ani-digits min 7 max 10
dial-peer voice 100 pots
description Incoming From PSTN
destination-pattern .T
port 1/0:1
dial-peer voice 200 voip
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.1.1
dtmf-relay rtp-nte h245-signal h245-alphanumeric
pcameron
Under pots dial peeer 100 add the command 'direct-inward-dial'
