Adaptive Bandwidth allocation.
Apr 2nd, 2009
Dear Experts,
I need your help to identify the problem in this configuration .
This is the example scenario.
Total Bandwidth Available 512Kbps.
Cust A - CIR 256Kbps PIR also 256Kbps
Cust B - CIR 256Kbps PIR 512Kbps
Config -
policy-map test1
class Test1 ! Cust B
shape average 512000
bandwidth 256
class test2 ! Cust A
bandwidth 256
shape average 256000
After applying this i've montiored around 64Kbps getting for Cust A when the Cust B using whole bandwidth (512Kbps).
How i can sort out this problem ? ( IOS - spservices,1841 Router )
Overall Rating: 4.5 (2 ratings)
Joseph W. Doherty Fri, 04/03/2009 - 04:31
The Cust A configuration shouldn't limit itself to 64 Kbps. What's the physical toplogy?
PS:
BTW, for Cust B, if you really want
you might want a variation of
policy-map test1
shape peak 256000
iboxzipper Fri, 04/03/2009 - 07:20
thanks for the response,
FA0/0 -> Router -> Fa0/1
Fa0/0 i've police rate for 512 Kbps, and applied fa0/1 particular policy shaping. if i use shape peak 256 also the same problem comes in the practical scenario. the router that given 256 peak utilize the around 47KBps. and other one get around only 16KBps. I'm really confused with what documents says.(http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfcbshp.html)
Joseph W. Doherty Fri, 04/03/2009 - 07:43
If you're both inbound policing in fa0/0 and outbound shaping on fa0/1, poor performance might be due to the policer. What's the policer's config?
Why are you both policing and shaping? Normally, you use one or the other, not both serially.
iboxzipper Fri, 04/03/2009 - 09:24
Hi ,
Actual requirement is more complex than what I've explained. Its like ISP provides only 512Kbps that's the reason I've put the police rate on fa0/0. This is to simulate the same scenario. Is there anyway i can prioritize that particular 256Kbps ?
Joseph W. Doherty Fri, 04/03/2009 - 09:40
"Is there anyway i can prioritize that particular 256Kbps"
Yes, either using a shaper alone or a hierarchal policy map.
e.g. (hierarchal policy map)
class-map match-(any or all) 256Kb
match . . .
policy-map shape_out_to_512Kb
class class-default
service-policy prioritize_256Kb
policy-map prioritize_256Kb
class 256Kb
bandwidth 256000
interface fa0/1
service-policy output shape_out_to_512Kb
iboxzipper Fri, 04/03/2009 - 09:55
thanks for the reply & for ur time, I'll check this on tomorrow with real setup & let you know the results.
iboxzipper Sat, 04/04/2009 - 23:08
Hi ,
Here i've attached the configuration. I could only add police-rate& bandwidth . I tried to add shape average then I got "GTS : Can be enabled only at the first level" error. But it gave the prioritization even though it is not 256Kbps. when i doing the download from one ftp site i noticed I'm getting around 160Kbps only. any help ?
Thanks in Advance .
Joseph W. Doherty Sun, 04/05/2009 - 04:38
Ah, well then . . .
class class-default
service-policy customers
policy-map customers
class custB
bandwidth 256000
class class-default
no fair-queue
interface fa0/1
Notes:
You'll need a class-map for custB. Since you're doing NAT, that becomes a bit more complex. One method might be to mark packets before NAT and match on the markings.
The above will guarantee 256 Kbps for custB, but will allow either custA or custB to use more bandwidth if available.
The above should work well for outbound.
iboxzipper Sun, 04/05/2009 - 05:05
Hi josephdoherty ,
thanks for the support on this. Actual implementation doesn't having natting :). only contain around 8 customers with 6Mbps connection from ISP.
I've done some testing with police rate and different burst rate. That produced what i expected. real testing will be in this week.:)) i'll let you know the results . Thanks again for the support.
Joseph W. Doherty Sun, 04/05/2009 - 05:10
"Actual implementation doesn't having natting "
That makes things easier, but then why does your posted running-config.txt show . . .
interface FastEthernet0/0
ip address x.y.z.4 255.255.255.240
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
service-policy output shape_512
iboxzipper Sun, 04/05/2009 - 06:14
this is actually test setup. Otherwise need to answer the customers :). As i mentioned real setup has 5.5Mbps connection divided to 8 customers one main customer can utilize all 5.5 Mbps when the others are not using. Earlier queuing configuration gave some problem that's why i started to test everything. I applied the real queuing like this.
policy-map shape-cbq
class CustA
bandwidth 64
police rate 64000 bps burst 32000 bytes
class CustB
bandwidth 160
police rate 160000 bps burst 64000 bytes
class CustC
bandwidth 350
police rate 350000 bps burst 128000 bytes
class CustD
bandwidth 2048
police rate 2048000 bps burst 512000 bytes
class CustE
bandwidth 256
police rate 256000 bps burst 128000 bytes
class CustF_Night
bandwidth 128
police rate 128000 bps burst 32000 bytes
class CustG
bandwidth 512
police rate 512000 bps burst 128000 bytes
class CustH
bandwidth 64
class CustI_Temp
bandwidth 128
class CustJ
bandwidth 64
policy-map shaper_5_5M
class class-default
shape average 5632000
service-policy shape-cbq
Again thanks. :)
