CME 3.3 upgrade
Apr 3rd, 2009
Hi all,
Is it possible to upgrade CallManager Express software to newer version?
We have router 2811 (2811, 256MB RAM, 64MB FLASH) with old CallManager Express 3.3 (IOS version: c2800nm-spservicesk9-mz.124-3g.bin), and needing to connect unsupported new types of phones Cisco 7911, Cisco 7961.
What is necessary for successful upgrade?
Best regards,
Miroslav Petkovic
miroslavpetkovic Fri, 04/03/2009 - 07:18
I found IOS: c2800nm-spservicesk9-mz.124-23.bin.
When I try to copy this IOS on empty flash, process failed after 98% (33,546,240 bytes).
Result was same when I tried to load IOS from TFTP server, process failed after 98% (33,546,240 bytes).
After crossing a border of 33MB of loaded IOS, there starts to appear O signes (OOOOOOOOOOOOOOOOOO....),and it never ends, so I need to power cycle my router to make it load the old IOS.
Thanks!
BR
Miroslav
dezoconnor Fri, 04/03/2009 - 07:40
Hi Miroslav, do you have enough room on your flash? Thats possibly why its failing, not enough capacity. Take a back up of the old IOS, delete, then try again.
Darren
miroslavpetkovic Fri, 04/03/2009 - 08:23
I tried to load IOS on empty flash, and it was same.
BR,
Miroslav
