MOH audio file requirements
Endorsed Question
Apr 3rd, 2009
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fsmoh.html#wp1028075
What is the normal size of MOH file?
Is it normal to use 450kb audio MOH file?
Cisco Endorsed by Mohit Grover
Rob Huffman about 8 years 1 month ago
Hi Alex,
Just to add a note to the good advice from Gonz;
Just be aware of this restriction that was introduced in CCM 5.x and carries over to 6.x (the individual filesize is not the main factor but rather the overall disc usage) ;
Storing Audio Source Files
In previous releases, Cisco CallManager did not limit the amount of space that MOH files used. The MOH upload tool does not limit the number of uploaded files or the file size. The modified upload JSP pages check the disk usage of existing MOH files and only permit uploads if sufficient space is found.
Note The smallest node on the cluster controls MOH capacity
The following considerations also apply:
•Release 5.0 of Cisco CallManager supports up to five MOH audio sources on 36- or 40-gigabyte disk-based systems. Systems with 72- or 80-gigabyte disks support the entire 50 audio streams.
•To increase the number of audio sources that Cisco CallManager supports, install a larger disk during upgrade.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmfeat/fsmoh.html
Format:
Average Data Rate 8.0 kb/second
Sample Rate 8.0 Khz
Audi Sample Size 8.0 Bit
Channels 1 (Mono)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
gogasca Fri, 04/03/2009 - 02:16
  • Green, 3000 points or more
yes its ok, not a problem.
Rob Huffman Fri, 04/03/2009 - 06:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alex,
Format:
Sample Rate 8.0 Khz
Channels 1 (Mono)
Hope this helps!
Rob
