SCE CM and SM in one server?
Answered Question
Apr 3rd, 2009
Can i install Subscriber Manager (SM) on the existing Collection Manager (CM) server?
Can SM and CM work properly in one server?
Any input is appreciated. Thank you
Correct Answer by jasmina27s about 8 years 2 weeks ago
It is in the user guide for CM. Similar statement can be found in the user guide for SM.
http://www.cisco.com/en/US/docs/cable/serv_exch/serv_control/broadband_app/rel350/cmug/Installing_the_Collection_Manager.html#wp1044427
Jasmina
Overall Rating: 3 (2 ratings)
cisco4kaleem Sun, 04/05/2009 - 23:40
eneral: IPV 6 Deployment in IPCC ,Rogger & CM.
Posted by: cisco4kaleem - consultnat, al jeraisy
Apr 5, 2009, 10:34pm PST
HI
As there is a plan to upgrade from IPV 4 to IPV 6 want to make sure if the system need to be upgrade to support IPV 6
the version of Rogger A,B is MS Win 2003
AWSA and B MS wind 2003
CM A&B is 4.1 Windows 2000
IVR A and B Windows 2000
1. Current systems readiness for understanding the packet format of IPV6. This covers HW, SW (OS and DB), and Application
2. Current systems readiness for migrating to the new IPV6. This covers HW, SW (OS and DB), and Application
Appreciate early response.
jasmina27s Tue, 04/07/2009 - 00:21
No. It is not supported by Cisco (If you want Cisco TAC support, it needs to be on separated servers).
It is even stated in the documentation: "The CM must run on its own machine. You cannot run it on the same machine as the Subscriber Manager and/or other applications."
For testing purposes it is possible to install it on one server. Generally, it works.
Best regards,
Jasmina
nizammuddin Thu, 04/09/2009 - 00:26
Hi Jasmina,
Thank you.
Could you please tell me where is the statement
can be found? I search in the documentation and cannot find it.
Thank you.
nizammuddin Tue, 04/14/2009 - 01:14
Hi Jasmina,
The statement can be found in user guide for SM and CM version 3.5.0.
I did not see it because I only refer to user guide version 3.1.5.
Thank you Jasmina. You really helps me a lot. Thanks.
Best regards,
Nizam
