ACE and ANM using ? in redirect statement
Apr 3rd, 2009
I want to use a "?" in a webhost-redirection statement.
If the ? this is added on the command line, the ? will induce help, to prevent this you can precede it with a crtl-v. This works.
With ANM if you add the redirection statement in full, and download to the ACE, everything after and including the ? is removed (due to help).
If I configure from CLI and re-sync to ANM it appears in the GUI config, however if I re-deploy to the ACE it is again removed.
What is the magic sequence of characters in ANM to keep the ?, and not forgetting ctrl-v is also paste in windows.
drolemc Thu, 04/09/2009 - 13:39
Are you doing this config from the GUI or CLI? If you are using the GUI could you please try from the CLI and use "ctrl v" before you type the "?" in the path. Ctrl vdoes not work in the gui. I found that if you encode the ? as %3F then the browser does not interpret it as a query delimiter in some cases.
