Discards on WAN MultiLink Interface
Apr 3rd, 2009
I am working at a Customer site today. They have an MPLS circuit that is effectively 2 T1's bundled together on a 3800 series ISR.
We have been noticing some output drops when we do a sho interface. They are pretty excessive in light of the fact that we do not have alot of load on that interface, and the reliability of the interface is at 255/255.
Here is a sample output from the interface:
GAMPLSRTR01#sho int multi1
Multilink1 is up, line protocol is up
Hardware is multilink group interface
Internet address is X.X.X.X/30
MTU 1500 bytes, BW 3072 Kbit, DLY 100000 usec,
reliability 255/255, txload 126/255, rxload 26/255
Encapsulation PPP, LCP Open, multilink Open
Open: IPCP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 2 seconds on reset
Last input 00:00:10, output never, output hang never
Last clearing of "show interface" counters 00:02:21
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2946
Queueing strategy: fifo
Output queue: 22/40 (size/max)
30 second input rate 321000 bits/sec, 322 packets/sec
30 second output rate 1520000 bits/sec, 345 packets/sec
44962 packets input, 5045539 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
53031 packets output, 35239499 bytes, 0 underruns
0 carrier transitions
GAMPLSRTR01#
This reading was taken just a minute or so after the interface counters were cleared.
What would be the most obvious causes of these drops, in light of the fact that we are not hammering our MPLS link?
Could it be our configured Class of Service Policies? What else could potentially cause these drops?
Thanks much. I am in desparate need to explain this today if possible and currently am not sure what is going on.
K-melton
Giuseppe Larosa Fri, 04/03/2009 - 06:24
  • Hall of Fame,
    Founding Member
Hello Kevin,
packets are sitting in the output queue waiting to be transmitted when the max size of the queue is reached (40 packets) you get outputs drops caused by tail drop.
Hope to help
Giuseppe
Kevin Melton Fri, 04/03/2009 - 06:43
Is there a way to change this size of the output queue?
Thanks!
Giuseppe Larosa Fri, 04/03/2009 - 07:02
  • Hall of Fame,
    Founding Member
Hello Kevin,
int type x/y
hold-queue 4096 out
verify the max size can be lower on your router
Hope to help
Giuseppe
Kevin Melton Fri, 04/03/2009 - 07:10
The Queuing strategy on the interface changes when we re-apply our Class of Service Policies. We had lifted those to see if they were causing the problem this morning.
Here is the output when we re-apply the policy map to the Multilink Interface:
reliability 255/255, txload 76/255, rxload 29/255
Last input 00:00:34, output never, output hang never
Last clearing of "show interface" counters 00:00:23
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 12
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/3/256 (active/max active/max total)
Reserved Conversations 4/4 (allocated/max allocated)
Available Bandwidth 3072 kilobits/sec
30 second input rate 352000 bits/sec, 342 packets/sec
30 second output rate 924000 bits/sec, 368 packets/sec
7734 packets input, 962720 bytes, 0 no buffer
8523 packets output, 2907859 bytes, 0 underruns
GAMPLSRTR01#
Giuseppe Larosa Fri, 04/03/2009 - 07:45
  • Hall of Fame,
    Founding Member
Hello Kevin,
you had a default FIFO queueing
now you have applied CBWFQ
Do you see an improvement ?
I see there are still some output drops
Hope to help
Giuseppe
Kevin Melton Fri, 04/03/2009 - 09:47
Guiseppe
Unfortunantly we are still having errors whether we have our CoS policy in place or not.
I wonder if we may have to make some adjustments to how our policy is configured. This is an exhorbitent amount of errors.
The two physical serial interfaces have 0 errors on them.
Not sure what to try next...
thanks
K-melton
Giuseppe Larosa Fri, 04/03/2009 - 09:57
  • Hall of Fame,
    Founding Member
Hello Kevin,
I would consider to configure the two serial interfaces as parallel L3 links with different ip numbering and to see how the router behaves.
Also check the stats of the mlppp bundle with
sh ppp multilink
see if there are errors
Hope to help
Giuseppe
Kevin Melton Wed, 04/08/2009 - 06:12
I performed the "sh ppp multilink" as you had recommended.
Here is the output:
GAMPLSRTR01#sho ppp multilink
Multilink1, bundle name is group6726
Endpoint discriminator is group6726
Bundle up for 2w4d, total bandwidth 3072, load 106/255
Receive buffer limit 24000 bytes, frag timeout 1000 ms
0/0 fragments/bytes in reassembly list
0 lost fragments, 3258146 reordered
0/0 discarded fragments/bytes, 0 lost received
0x693933 received sequence, 0xA7E88A sent sequence
Member links: 2 active, 0 inactive (max not set, min not set)
Se0/1/0:0, since 2w4d
Se0/0/0:0, since 2w4d
No inactive multilink interfaces
As you can see, there are no errors.
This problem has been baffling us for some time now. The output errors/discards that we are seeing will run excessively for awhile, and then like magic, just stop. Then they will start again.
We have tried adjusting our CoS policies around to see if this makes any difference. We even attempted taking the policies off altogether as you will remember when I originally posted to this forum.
I wonder at this point if it would be worth unbundling the interfaces that make up the multilink and then re-bundling them.
Any recommendations at this point will be welcome.
paolo bevilacqua Wed, 04/08/2009 - 06:18
  • Hall of Fame,
    Founding Member
There is nothing to be baffled about. At some point, traffic rate offered is bigger than what the queue can accommodate (burst), and drops occur. That is perfectly normal in WAN networking.
You can increase a little the queue size, I would not go over 2 or 300 packets anyway.
If you cannot tolerate packet drops, reduce load on the circuit, or buy a faster circuit.
