Directory for another cluster
Apr 3rd, 2009
We have 2 callmanger clusters that has a trunk connection. one of the callmanagers has been upgraded to version 6.1
before the upgrade we could see the directory of both clusters. now on callmanager 4 when we press the directory for the other cluster (now ver 6.1)
we get a tomcat 5.5.17 error.
We edited the xml file to point to a jsp file as opposed to asp.
We are using 7940 phones.
any ideas?
msabir Fri, 04/03/2009 - 06:40
  • Bronze, 100 points or more
Sounds like your URL is not correct. Can you post the URL for 6.1 directory?
pcromwell Mon, 04/06/2009 - 01:16
I should have mentioned that 8080, was already in there.
I still have the same problem, any ideas of where to look
msabir Mon, 04/06/2009 - 07:52
Are you using host name or IP address in the URL?
Can you open the URL in a web browser and does it still give you an error? If so, what is the exact error message?
pcromwell Mon, 04/06/2009 - 11:03
an ip address is being used in the URL
in the url it opens o.k you see the xml file displayed on the browser.
