Troubleshooting WAN (FastE) interface "input errors"
Apr 3rd, 2009
I'm having trouble convincing my ISP that I'm having problems. I have a Cisco 1811 router with two WAN interfaces connected up to two different ISPs. One ISP connection (on my FastEthernet1 interface) is having no problems...and I'm seeing no errors on that interface. I'm having "slowness" problems on my other ISP ...here's a show int:
#show int faste0
FastEthernet0 is up, line protocol is up
Hardware is PQ3_TSEC, address is 001f.6c8f.8c3e (bia 001f.6c8f.8c3e)
Description: XXXX WAN Internet Internet address is x.x.x.x/29
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:23, output 00:00:05, output hang never
Last clearing of "show interface" counters 1d11h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
54569 packets input, 60095887 bytes
Received 6406 broadcasts, 0 runts, 0 giants, 0 throttles
3644 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
50499 packets output, 12836792 bytes, 0 underruns
0 lost carrier, 0 no carrier
I've done everything *I* can do, I've swapped patch cables between the router and the ISP's media converter, I've swapped the ISPs between FastE0 and FastE1 (the input errors follow the "bad" ISP's connection)
I've changed speeds & duplex...that didn't fix it either... I'm still getting "input errors"
Is there anything I can do to find out more about these "input errors"... note that the CRC, frame, overrun, etc. counters don't go up at all... just these "input errors"
Any thoughts? (the ISP denies any problems)
lamav Sat, 04/04/2009 - 06:32
  • Blue, 1500 points or more
I know this sounds like a non-answer, but its time to escalate through your management and get the teclo to look at the circuit.
