MPLS-Aware NetFlow for 7600
Apr 3rd, 2009
The MPLS-Aware NetFlow feature is supported by 7200, 7500 and 12000 platforms only. Will it be supported by 7600 in the nearest future?
Overall Rating: 4 (2 ratings)
e.shik_i-teco Sun, 04/05/2009 - 23:02
The command "ip flow-cache mpls label-positions [label-position-1 [label-position-2 [label-position-3]]]" is availiable neither in c7600s72033-advipservicesk9-mz.122-33.SRC.bin nor c7600s3223-advipservicesk9-mz.122-33.SRC3.bin. Although (MPLS)-aware NetFlow is pointed out in Cisco Feature Navigator in both versions.
Laurent Aubert Mon, 04/06/2009 - 06:13
I went deeper in my research and unfortunately, the documentation is wrong. MPLS aware Netflow is not supported on the 7600 platform.
Sorry for that
e.shik_i-teco Mon, 04/06/2009 - 06:20
Thank you very much for your reply! Do you know whether this feature will be introduced in the next version of IOS?
aneuf Fri, 10/30/2009 - 07:00
Has anyone another idea how to get IP-flow information/statistics out of an MPLS-Stream?
Mirror-ports/probes might be a solution too.
In case of my customer ingress Netflow is not an option.
a.manosca Thu, 02/04/2010 - 01:15
MPLS-Aware NetFlow feature does not seem to be supported still in 12.2(33) SRD and SRD3 on a 7600, regardless of the feature set.
Any news if this feature will be supported?
