1841 Routers & 2Mb Leased Line - Sessions dropping
Apr 3rd, 2009
We have a customer with 2 sites, and a recently deployed 2Mb Leased line circuit between them. As the service provider does not provide routers, the customer has purchased an 1841 router for each site, along with a suitable serial interface to connect to the X21 interface on the provider eqpt.
With everything connected up, the serial interfaces come up ok (L1 and L2), and it's possible to ping/telnet to the remote router, and a server which sits on it's LAN interface. However, if we try to send a file to the remote server - the transfer starts to take place, and after about 10 seconds of transferring data the session times out, and we see CRC & input errors (equal in value) on the serial interface of the far end router.
I have cleared the counters to be sure, and can confirm that it's when the session dies, the counters increment.
I've tried a couple of things to try to get this working, one of which was to implement traffic shaping on the local router in the outbound direction to limit the rate at which the data was being sent. This made no difference, other than it took longer for the transfer to fail.
The Bandwidth on the serial interface at each end is configured ok. I've tried both HDLC and PPP encapsulation, and it makes no difference - the transfer still fails after a few seconds.
Both routers are running IOS 12.4-15.T7, and I've captured the config of the serial interface config for both routers, along with a 'show interface' on both routers
Any help or advice appreciated.
-Gordon.
gordonmarkus Fri, 04/03/2009 - 08:28
The captures are here as they wouldn't fit in the original post:
interface Serial0/1/0
description Link to CC-FTM-02
bandwidth 2048
encapsulation ppp
fair-queue
Serial0/1/0 is up, line protocol is up
Hardware is GT96K Serial
Description: Link to CC-FTM-02
Internet address is 192.168.1.1/24
MTU 1500 bytes, BW 2048 Kbit/sec, DLY 20000 usec,
Encapsulation PPP, LCP Open
Open: IPCP, CDPCP, loopback not set
Keepalive set (10 sec)
CRC checking enabled
Last input 00:00:18, output 00:00:04, output hang never
Last clearing of "show interface" counters 00:02:29
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1536 kilobits/sec
5 minute input rate 0 bits/sec, 1 packets/sec
5 minute output rate 13000 bits/sec, 1 packets/sec
835 packets input, 57612 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1225 packets output, 1181027 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
Serial0/0/0 is up, line protocol is up
Description: Link to CC-FTM-01
Internet address is 192.168.1.2/24
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:03:38
Conversations 0/1/256 (active/max active/max total)
5 minute input rate 3000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
1317 packets input, 1177403 bytes, 0 no buffer
7 input errors, 7 CRC, 7 frame, 0 overrun, 0 ignored, 7 abort
924 packets output, 62932 bytes, 0 underruns
interface Serial0/0/0
description Link to CC-FTM-01
bandwidth 2048
ip address 192.168.1.2 255.255.255.0
encapsulation ppp
fair-queue
end
-Gordon.
DialerString_2 Fri, 04/03/2009 - 15:22
  • Bronze, 100 points or more
Gordon,
Those CRC errors could mean either the device sending the traffic is bad, patch cable is bad and/or duplex setting are off.
gordonmarkus Sat, 04/04/2009 - 04:14
Cool - thanks for that. I'll get the hardware checked out.
-Gordon.
