04-03-2009 08:47 AM
Hi All,
The L2L session having prod traffic between ASA5510<-->2811 router resets every 24hrs. I believe this is due to default isakmp lifetime (86400Sec).The ASA has option to change the lifetime for the isakmp...
5510-V1(config-isakmp-policy)# lifetime ?
crypto-isakmp-policy mode commands/options:
<120-2147483647> Lifetime in seconds
none Disable rekey and allow an unlimited rekey period
But the router (2811- c2800nm-advipservicesk9-mz.124-8b.bin) do not have the option..
2811-FW1(config-isakmp)#lifetime ?
<60-86400> lifetime in seconds
Is there anyway we can keep the Tunnel up without loosing it..? If I change on the ASA for this particular 'isakmp policy', does it take effect on the other peers (ex: 2811) which are using this policy to connect or the lower interval always takeover..?
Thank you in advance.
MS
04-03-2009 09:27 AM
I am unsure if there is the command for the 2811. I have not worked with that specific model. Hopefully someone else can answer that. However with regards to the timers etc I would have thought leaving as is would be ok and a good idea. This means it will refresh the phase 1 tunnel (isakmp sa) every 24hrs. As long as interesting traffic is still being sent then then VPN should just renegotiate.
Hope that helps
04-03-2009 09:57 AM
Thank you. Iam wondering any if any latest IOS versions got that option on 2811. Lets see if any other 'guru' replies. Also, what is time for isakmp to reestablish/rekey?
Thank you
MS
04-06-2009 07:15 AM
By default ISAKMP is renegotiated every 24hrs by default.
Hope that helps
