QoS Help Please on 2811 with NM-16ESW
Apr 3rd, 2009
We're using Cisco 2811's at branch sites. I need help with the QoS configuration on the Fast0/0 interface and also for the NM-16ESW. We're testing on a cable modem connection (yes I know this is not optimal) with 6 Mbps download and 512 Mbps upload. All works great except for when I stress test the WAN link.
I have the following config for Fast 0/0:
class-map match-any QoS-VoIP-RTP-Trust
match protocol rtp audio
match access-group name QoS-VoIP-RTCP
class-map match-any QoS-VoIP-Control-Trust
match access-group name QoS-VoIP-Control
policy-map QoS-Policy-Trust
class QoS-VoIP-RTP-Trust
priority 128
class QoS-VoIP-Control-Trust
bandwidth 64
class class-default
fair-queue
interface FastEthernet0/0
description Road Runner Cable Modem
ip address dhcp
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
crypto map 3DESmap
service-policy output QoS-Policy-Trust
ip access-list extended QoS-VoIP-Control
permit tcp any any eq 1720
permit tcp any any range 11000 11999
permit udp any any eq 2427
permit tcp any any eq 2428
permit tcp any any range 2000 2002
permit udp any any eq 1719
permit udp any any eq 5060
ip access-list extended QoS-VoIP-RTCP
permit udp any any range 16384 32767
No packets voice packets are being classified as voice:
XXX-2811#show policy-map interface fastEthernet 0/0
FastEthernet0/0
Service-policy output: QoS-Policy-Trust
queue stats for all priority classes:
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
Class-map: QoS-VoIP-RTP-Trust (match-any)
0 packets, 0 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: protocol rtp audio
0 packets, 0 bytes
30 second rate 0 bps
Match: access-group name QoS-VoIP-RTCP
0 packets, 0 bytes
Priority: 128 kbps, burst bytes 3200, b/w exceed drops: 0
Class-map: QoS-VoIP-Control-Trust (match-any)
0 packets, 0 bytes
Match: access-group name QoS-VoIP-Control
0 packets, 0 bytes
Queueing
bandwidth 64 kbps
Class-map: class-default (match-any)
9354 packets, 1393816 bytes
Match: any
Queueing
(queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
(pkts output/bytes output) 9354/1394362
Fair-queue: per-flow queue limit 16
On the NM-16ESW ports I have the following configured for all ports:
interface FastEthernet1/0
switchport voice vlan 2
load-interval 30
mls qos trust cos
Can someone please help me with both the QoS config for Fast0/0 (the WAN interface) and also for the NM-16ESW interfaces? Can we also police the inbound interface to ensure some room is left for voice packets? Can you provide an example?
jordan.bean Fri, 04/03/2009 - 11:08
I think I have this figured out. Things appear to be working under load:
class-map match-all voice-signaling
match dscp af31
class-map match-all voice-traffic
match dscp ef
policy-map qos-voice-child
class voice-traffic
priority 66
class voice-signaling
bandwidth 32
class class-default
fair-queue
class class-default
shape average 512000
service-policy qos-voice-child
ip address dhcp
ip nat outside
rate-limit input 4496000 32000 32000 conform-action transmit exceed-action drop
load-interval 30
duplex auto
speed auto
crypto map 3DESmap
service-policy output qos-voice
I'm using a parent/child policy map to first shape for the 512kbps outbound. I then prioritize the voice/signalling traffic. This seems to be working.
On the outbound, I just set a rate-limit to ensure that there is always bandwidth available for voice traffic. Any other suggestions for this so I can take advantage of the unused bandwidth?
slotking22 Wed, 01/13/2010 - 18:18
hi,
I am trying to get 2600 I just purchase to connect to road runner with DHCP!
but I am not having any luck!!!
I posted it here, because you seem to have it working
I even tried to hook it to my wireless router to see if the port would pull an IP address.
the interface config is
description internet
ip address dhcp
ip accounting output-packets
ip nat outside
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
no cdp enable
I do have DHCP server enabled on the router to hand out dhcp on the lan side and that does work
slotking22 Sun, 01/17/2010 - 14:36
also found this:
If I remove the last option (option 52) from the emulated dhcp discovery packet the cable modem successfully answer the cisco request with a dhcp offer. Further actions like answering to the dhcp offer are beyond the scope of my test and no further actions were taken by the emulation program.
Conclusions:
»www.cisco.com/en/US/docs/net_mgm···Opts.pdf
Option 52 is used by DHCP as an additional space in case the server needs to send back additional data to the client. For some reason the cable modem is not answering the cisco request if this option is present.
