IP communicator can't register in CME using SIP
Apr 3rd, 2009
IP communicator can register in CME4.2 using SCCP protocol.
I tried to IP communicator register in CME4.2 using SIP protocol but can't register CME.
Is it possible mode or CME4.2 can't supported this mode(ip communicator using SIP protocol)?
ps:IP communicator can register in CCM 7.0 using SIP or SCCP.
Nicholas Matthews Fri, 04/03/2009 - 18:43
Do you have all of the SIP CME configuration? It's very different from the SCCP configuration.
-nick
mike.hsueh Sun, 04/05/2009 - 17:55
My config..
voice service voip
allow-connections sip to sip
sip
registrar server expires max 1200 min 300
voice register global
mode cme
source-address 10.36.198.50 port 5060
max-dn 20
max-pool 10
tftp-path flash:
create profile sync 0001985642831255
voice register dn 1
number 999
allow watch
voice register pool 1
id mac 001A.4D58.0BB0
number 1 dn 1
dtmf-relay sip-notify
username cisco password cisco
FYI...
Cisco Unified Communications Manager Express:SIP Implementation Guide...
id mac 0016.47CD.9BD7
type 7970
The tpye was wichout CIPC choice..
so I think CME maybe doesn't supports.
mike.hsueh Mon, 04/06/2009 - 03:33
I got it...FYI..
This release is supported with Cisco IP Communicator Release 7.0:
• Cisco Unified Communications Manager Express Release 4.1 (SCCP)
When Cisco IP Communicator is running SIP as its call-control protocol, it does not support SRST or
Cisco Unified Communications Manager Express. (CSCsh69835)
Nicholas Matthews Mon, 04/06/2009 - 05:09
Hi Mike,
If you can't enter the 'type' command it won't be officially supported. Quite often you can get it to register anyways as long as you can get the username and password on the phone.
-nick
evandro.nunes Thu, 12/30/2010 - 13:13
I configured the IP Communicator (version 7.0) on CME 7.1 as type 7970 and it works fine.
dijohn Sun, 01/02/2011 - 13:31
I wrote a post on this sometime back
IP Phone  ==VLAN 422=== Router ==VLAN 426===CCME Router
Here’s “why” ,”how”, “What happens if”  to the commands used in SIP Phone Registration to CCME.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
#### SIP Phones create Voip Dial-peers. so for SIP to SIP, SIP to H323   you need to allow the connections. SCCP phones create EFXS POTS   dial-peer. By Default IP-IP call is blocked)(Random Fact).
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
bind control source-interface FastEthernet0/0.426
bind media source-interface FastEthernet0/0.426
### Bind Control and media to the interface with the same IP Address on   source-address x.x.x.x . Else you will run into problems when you try  to  register Phones over a Layer 3 Link.
registrar server
### Needed for phone to register
mode cme
### Change mode to CME
source-address 14.160.126.77 port 5060
### Should be the same as bind control and media when you have InterVLAN Routing :)
max-dn 10
max-pool 10
authenticate register
### Needed for the phone to authenticate with username password, in intervlan registeration setup
tftp-path flash:
### All the config files for the phones will be stored here.
create profile sync 0174426467043125
### Make sure you enter this command everytime you make some changes.!!!!!! Very IMP!
voice register dn  1
number 1234
### DN for the Phone
id mac 0023.5E17.D275
### Mac Address of the Phone trying to register. Which won’t be used an   authentication method when registering in Intervlan register scenario
type 7942
### Make sure you have this in here.! Else SEP.config wouldn’t be created.
number 1 dn 1
### Assigning 1234 to line 1 on the phone
### Credentials the phone uses when it tries to register in case of intervlan.
Relevant debugs
Received:
REGISTER sip:14.160.126.77 SIP/2.0
Via: SIP/2.0/UDP 14.160.122.228:5060;branch=z9hG4bKdf9fece6
To:
Call-ID: [email protected]
Max-Forwards: 70
Date: Thu, 14 Oct 2010 07:04:30 GMT
CSeq: 103 REGISTER
User-Agent: Cisco-CP7942G/8.5.2
Contact:   ;+sip.instance=””;+u.sip!model.ccm.cisco.com=”434″
Supported:   replaces,join,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-3.0.0,X-cisco-xsi-7.0.1
Content-Length: 0
Reason: SIP;cause=200;text=”cisco-alarm:105 Name=SEP00235E17D275 Load=SIP42.8-5-2SR1S Last=config-retry-restart”
Expires: 3600
*Oct 14 07:08:12.015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
Date: Thu, 14 Oct 2010 07:08:12 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 103 REGISTER
Content-Length: 0
*Oct 14 07:08:12.111: VOICE_REG_POOL: Register request for (1234) from (14.160.122.228)
*Oct 14 07:08:12.111: VOICE_REG_POOL: key(B99A11AB0176754A) added to nonce table
*Oct 14 07:08:12.111: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: ;tag=EA0947C-241F
CSeq: 103 REGISTER
WWW-Authenticate: Digest realm=”",nonce=”B99A11AB0176754A”,algorithm=MD5,qop=”auth”
Content-Length: 0
Received:
Via: SIP/2.0/UDP 14.160.122.228:5060;branch=z9hG4bK0ca509fe
To:
Max-Forwards: 70
CSeq: 104 REGISTER
Authorization: Digest   username=”cisco”,realm=”",uri=”sip:14.160.126.77″,response=”dd2a196551c5598102e71c0eac92d89a”,nonce=”B99A11AB0176754A”,cnonce=”4a16becc”,qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Oct 14 07:08:12.127: VOICE_REG_POOL: Register request for (1234) from (14.160.122.228)
*Oct 14 07:08:12.131: VOICE_REG_POOL: Contact matches pool 1 number list 1
*Oct 14 07:08:12.131: VOICE_REG_POOL: key(1234) contact(14.160.122.228) add to contact table
*Oct 14 07:08:12.131: VOICE_REG_POOL: No entry for (1234) found in contact table
*Oct 14 07:08:12.131: VOICE_REG_POOL: key(1234) contact(14.160.122.228) added to contact table
*Oct 14 07:08:12.131: VOICE_REG_POOL pool->tag(1), dn->tag(1), submask(1)
*Oct 14 07:08:12.131: VOICE_REG_POOL: Creating param container for   dial-peer 40001.VOICE_REG_POOL pool->tag(1), dn->tag(1),   submask(1)
VOICE_REG_POOL pool_tag(1), dn_tag(1)
*Oct 14 07:08:12.135: VOICE_REG_POOL: Created dial-peer entry of type 0
*Oct 14 07:08:12.135: VOICE_REG_POOL: Registration successful for 1234, registration id is 1
*Oct 14 07:08:12.143: VOICE REGISTER POOL-1 has registered. Name:SEP00235E17D275  IP:14.160.122.228  DeviceType:Phone
*Oct 14 07:08:12.143: VOICE_REG_POOL: Pool[1]: service-control (reset type: 2) message sent to sip:[email protected]
*Oct 14 07:08:12.143: VOICE_REG_POOL: Contact matches pool 1 number list 1
*Oct 14 07:08:12.183: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 104 REGISTER
Content-Length: 0
*Oct 14 07:08:12.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 104 REGISTER
Contact: ;expires=3600;x-cisco-newreg
Expires:  3600
Content-Length: 0
Let me know if something is wrong :)
PS. Rate useful posts
