CallManager 5
Answered Question
Apr 3rd, 2009
Hello folks,
do you know the cli command to shrink or flush the hard drive on the server.
I have an alert on one of my servers
LowActivePartitionAvailableDiskSpace partition has 0 percent of available disk space.
I have no space, please help me out
Correct Answer by Michael Owuor about 8 years 1 month ago
Hello Cris,
To manually clean things up, you could use the RTMT Trace and Log Collection tool to download and delete files proactively. If you select the 'Collect Files' option, you will have the choice of deleting collected log files from the server.
Also take a look at the following DDTS for a process of deleting log files.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsg54205
Hope this helps.
Michael.
Overall Rating: 5 (1 ratings)
Correct Answer
Michael Owuor Fri, 04/03/2009 - 20:54
  • Cisco Employee,
Hello Cris,
Hope this helps.
Michael.
cris_jimenez Fri, 04/03/2009 - 21:38
could this be the cause of a HIGH cpu utilization on my servers?
