Interface Buffers 3750E
Apr 3rd, 2009
I am wondering if anyone has a map out of the Interface buffers when running the command show buffers.
There is a RxQFB
and
RxQ0 - RxQ15
Any help on what they map to for physical ports would be great. Seeing a lot of missing on RxQ9...
smalkeric Thu, 04/09/2009 - 05:50
This show buffers command output indicates a buffer leak in the middle buffers pool. Use the show controllers ethernet-controller privileged EXEC command without keywords to display per-interface send and receive statistics read from the hardware. Use with the phy keyword to display the interface internal registers or the port-asic keyword to display information about the port application-specific integrated circuit (ASIC).
Switch# show controllers ethernet-controller port-asic statistics
http://www.cisco.com/en/US/products/hw/iad/ps397/products_tech_note09186a00800a7b85.shtml
carl.wertz Wed, 04/15/2009 - 04:49
Thanks for the reply. My next question is, I am running the debug sanity. Then when I run the show buffers old I dont see anything in there. So this leads me to believe I am not having an issue with a buffer however it looks like I am missing something. Is there anymore information to debug this issue? I am running the latest IOS for the 3750 E series, 12.2(44)SE5.
