unity connection 7.x Alternate Contact Number
Answered Question
Apr 3rd, 2009
  • Green, 3000 points or more
Can subscribers update their alternate contact number through the TUI?
Overall Rating: 5 (1 ratings)
Tommer Catlin Fri, 04/03/2009 - 13:45
thanks man. I couldnt find it.. or it's friday. The Personal Transfer Rules, I have not quite figured out yet. Still working on those! But this works.
Rob Huffman Fri, 04/03/2009 - 13:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Tcat,
Yes, this is most possible (I was just testing this yesterday :)
To Specify an Alternate Contact Number by Using the Phone Keypad
For us (using Optional Conversation 1) the key sequence was Pin> 4 (change setup options)> 5 ( change Alternate Contact Number)
Step 1 Call and log on to Connection.
Step 2 At the Main menu, choose the options Setup Options > Alternate Contact Numbers.
Note Connection plays the prompt to configure alternate contact numbers only when one or more keys are configured to transfer to an alternate contact number.
Step 3 Follow the prompts to specify one or more alternate contact numbers. The prompts tell you which keys can be used to transfer to alternate contact numbers.
**Note: Connection plays the prompt to configure alternate contact numbers only when one or more keys are configured to transfer to an alternate contact number.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user/guide/phone/7xcucugphone160.html
Hope this helps!
Rob
Snooze you lose! My horrid typing skills have let me down again ;-)
