Easy networking question for the Vets..
Apr 3rd, 2009
I'm setting up 100 wireless laptops for my company's convention like so:
Cisco1720 Router >3COM switch> Cisco1200AP> wirelessClient.
the router is providing DHCP + NATing 1 pool of addresses (10.1.1.10- 100) out 1 eth0 WAN interface. I want to add a 2nd 1200AP to provide wireless for ~60 attendees but i'd prefer a 2nd DHCP pool w/ short lease and NAT those out same eth0 Wan interface. WHAT would be the easiest way to accomplish? if i create a 2nd pool/network on the router, say 10.1.99.1- 100
can i NAT those out the same interface. OR do i have to create VLANs? THANKS
Jon Marshall Fri, 04/03/2009 - 15:50
"can i NAT those out the same interface. How? THANKS"
Sure you can, just add it to the existing acl you use for NAT ie. lets say your existing pool is 192.168.5.0/24
you should have something like this on your 1720
access-list 101 permit ip 192.168.5.0 0.0.0.255
ip nat inside source list 101 interface eth0 overload
so just add your new pool to acl 101
Jon
fkleininger Fri, 04/03/2009 - 16:04
ok so here's my config:
I create a 2nd pool, and add those 2 statments and then i have to set my 2nd AP to use those addreses? i'm confusing myself :)
thanks
rsion 12.3
service password-encryption
hostname icaferouter
boot-start-marker
boot-end-marker
enable secret 5 $1$mm9l$73KJh6BcukJSDLg2s2TZ8/
clock timezone est -5
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp pool icafe
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
dns-server 1.1.1.1
lease 10
ip flow-cache timeout active 1
no ip domain lookup
ip name-server 205.171.2.65
no ftp-server write-enable
interface Ethernet0
ip address 71.216.212.235 255.255.255.248
ip nat outside
ip route-cache flow
shutdown
half-duplex
interface FastEthernet0
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip route-cache flow
speed 100
full-duplex
ip nat inside source list 1 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 71.216.212.238
no ip http server
access-list 1 permit 10.0.0.0 0.255.255.255
Jon Marshall Fri, 04/03/2009 - 16:12
Actually you don't need to add anything because your acl
covers the new pool of addresses you want to add. But which interface will these addresses come in on because fa0 is in the 10.1.1.x network ?
Do you have another interface or are you going to add a secondary address to fa0 ie.
int fa0
ip address 10.1.99.1 255.255.255.0 secondary
Jon
fkleininger Fri, 04/03/2009 - 16:15
no additional fa0 int, so i can create a secondary ip with that statment above?
fkleininger Fri, 04/03/2009 - 17:02
Hummmm, still not getting an IP in the x.x.99.x range
am i missing something???
++++++++++++++++++++++++++++++++++++++++++++++++++++++++AP CONFIG ++++++++++++++++++++++
enable secret 5 $1$jD8w$xwAvtjhSeMvtpuqZE1mjK.
username Cisco password 7 0802455D0A16
ip subnet-zero
ip dhcp excluded-address 10.1.1.1 10.1.1.100
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid aacrfreenet
guest-mode
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 2312
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
ip address 10.1.99.2 255.255.255.0
no ip route-cache
speed 100
full-duplex
bridge-group 1
interface BVI1
ip address 10.1.99.3 255.255.255.0
no ip route-cache
ip default-gateway 10.1.99.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
ip radius source-interface BVI1
bridge 1 route ip
!++++++++++++++++++++++++++++++++++ROUTER CONFIG ++++++++++++++
no mmi pvc
no aaa new-model
ip subnet-zero
ip cef
ip dhcp pool icafe
dns-server 1.1.1.1
lease 10
ip dhcp pool Freenet
network 10.1.99.0 255.255.255.0
default-router 10.1.99.1
lease 0 0 8
no ip domain lookup
interface Ethernet0
ip nat outside
ip route-cache flow
shutdown
half-duplex
ip nat inside
ip route-cache flow
speed 100
full-duplex
ip classless
ip flow-export source FastEthernet0
ip flow-export version 5
ip flow-export destination 71.216.212.236 9997
no ip http server
snmp-server community aacr RW
fkleininger Fri, 04/03/2009 - 17:42
i can connect, i just dont get an IP from the DHCP pool x.x.99.x,, i get a 10.1.1.x ip
Leo Laohoo Fri, 04/03/2009 - 18:02
"username Cisco password 7 0802455D0A16" < --- I know this is not related, but next time, remove this and other password-related line. It may be secure and safe in the router but over the net, it doensn't matter if the password is "Cisco". :)
fkleininger Fri, 04/03/2009 - 18:57
aahhhgggg!
r 13 18:22:16.255: DHCPD: DHCPRELEASE message received from client 0100.16ce.77b0.83 (10.1.1.11).
icaferouter#
Apr 13 18:22:34.207: DHCPD: DHCPREQUEST received from client 0100.16ce.77b0.83.
Apr 13 18:22:34.207: DHCPD: client has moved to a new subnet.
Apr 13 18:22:34.207: DHCPD: Sending DHCPNAK to client 0100.16ce.77b0.83.
Apr 13 18:22:34.211: DHCPD: broadcasting BOOTREPLY to client 0016.ce77.b083.
icaferouter#
Apr 13 18:22:35.255: DHCPD: DHCPDISCOVER received from client 0100.16ce.77b0.83 on interface FastEthernet0.
icaferouter#
Apr 13 18:22:37.255: DHCPD: Sending DHCPOFFER to client 0100.16ce.77b0.83 (10.1.1.13).
Apr 13 18:22:37.255: DHCPD: creating ARP entry (10.1.1.13, 0016.ce77.b083).
Apr 13 18:22:37.255: DHCPD: unicasting BOOTREPLY to client 0016.ce77.b083 (10.1.1.13).
Apr 13 18:22:37.343: DHCPD: DHCPREQUEST received from client 0100.16ce.77b0.83.
Apr 13 18:22:37.343: DHCPD: Sending DHCPACK to client 0100.16ce.77b0.83 (10.1.1.13).
Apr 13 18:22:37.343: DHCPD: creating ARP entry (10.1.1.13, 0016.ce77.b083).
Apr 13 18:22:37.343: DHCPD: unicasting BOOTREPLY to client 0016.ce77.b083 (10.1.1.13).
icaferouter#
icaferouter#
