MeetingPlace and Active Directory Sync setup problems
Apr 3rd, 2009
Hi I am having a problem setting up AD direcory services. Specifically in the meta-link between the MP Directory server and the Windows DC. The metalink between the Audio server and the DS server is working....I think
I am not really sure about modifying the ad-import.cfg file. I am looking at the doc-wiki and it is not specific enough for me. I wanted to see what would happen if I leave it default and what the results are.
I added a line, networkcredemtials = "mydomain\5c"+SAMAccountname to the bootstrappersonmap section as well to the importpersonpam.
The error I get is ERROR: failed to initialize the schema component with error 1206
I am running Audio server 6.0.3 with the appropriate Direcory Services sw.
I would apprecialte any help
Anonymous (not verified) Thu, 04/09/2009 - 18:10
Try to do the following:
- Run DC directory uninstall.
- Stop gwsim and all MeetingPlace services.
- Delete MPDS directory and all gwsim directories.
- Remove installshield for MPDS, it should be under c:\program files, look at setup.ini file to find out which directory is for MPDS and move it to other directory.
- Find MeetingPlace directory services key in registry and remove it.
- Reinstall MPDS.
