crow930us Sat, 04/04/2009 - 05:09
  • Bronze, 100 points or more
show cdp neighbors
To display detailed information about neighboring devices discovered using Cisco Discovery Protocol, use the show cdp neighbors command in privileged EXEC mode.
show cdp neighbors [type number] [detail]
Syntax Description
type (Optional) Interface type that is connected to the neighbors about which you want information; possible valid values are ethernet, fastethernet, gigabitethernet, tengigabitethernet, port-channel, and vlan.
number (Optional) Number of the interface connected to the neighbors about which you want information.
detail (Optional) Displays detailed information about a neighbor (or neighbors) including network address, enabled protocols, hold time, and software version.
Usage Guidelines
The vlan keyword is supported in Catalyst 6500 series switches that are configured with a Supervisor Engine 2.
The port-channel values are from 0 to 282; values from 257 to 282 are supported on the call switching module (CSM) and the firewall services module (FWSM) only.
