ISIS/CLNS routing weirdness?
Apr 3rd, 2009
  • Bronze, 100 points or more
I have just begun experimenting with ISIS and CLNS. Routers F, G, and H are on a multiaccess segment. I have enabled ISIS on all of them and configured "clns router isis" on their broadcast interfaces. They are all level-1-2 routers at the moment.
For kicks and giggles, I configured an additional NET on Router G. (CLNS- and ISIS-relevant configs are in the next post...)
All routers are in area 49.0100; G's extra NET puts it in area 49.0200 as well. What confuses me is that the output of "show clns route", on each machine, lists 49.0200 learned through IS-IS and 'via' themselves; rather than via Router G (which, as best I can tell, is the only router that actually links to area 49.0200).
Why do the routers believe they can get to G's area "via [themselves]?"
Here's the output of sh clns route on each:
Router-F>sh clns route
Codes: C - connected, S - static, d - DecnetIV
I - ISO-IGRP, i - IS-IS, e - ES-IS
C 49.0100 [2/0], Local IS-IS Area
C 49.0100.6001.6002.6003.00 [1/0], Local IS-IS NET
i 49 [110/10]
via Router-H, TokenRing0
i 49.0200 [110/0]
via Router-F
Router-F>
Router-G>sh clns route
C 49.0200 [2/0], Local IS-IS Area
C 49.0200.0009.2234.5432.00 [1/0], Local IS-IS NET
C 49.0100.0009.2234.5432.00 [1/0], Local IS-IS NET
i 49 [110/10]
Router-G>
Router-H>sh clns route
C 49 [2/0], Local IS-IS Area
C 49.0100.08de.5cab.00 [1/0], Local IS-IS NET
i 49.0100 [110/0]
via Router-G, TokenRing0
via Router-H
i 49.0200 [110/0]
via Router-H
Router-H>
CriscoSystems Fri, 04/03/2009 - 17:54
Router F config
clns routing
interface TokenRing0
ip address 10.4.4.6 255.255.255.0
ip router isis
ring-speed 16
clns router isis
router isis
net 49.0100.6001.6002.6003.00
Router G config
clns routing
interface Serial0
ip address 215.0.0.13 255.255.255.252
encapsulation ppp
no ip mroute-cache
no fair-queue
clockrate 1000000
clns router isis
interface Serial1
no ip address
encapsulation ppp
ip address 10.4.4.7 255.255.255.0
ip router isis
ip policy route-map word
ring-speed 16
clns router isis
router isis
net 49.0100.0009.2234.5432.00
net 49.0200.0009.2234.5432.00
Router-H
clns routing
ip address 10.4.4.8 255.255.255.0
ip router isis
clns router isis
router isis
net 49.0100.08de.5cab.00
Giuseppe Larosa Sun, 04/05/2009 - 03:35
  • Hall of Fame,
    Founding Member
Hello Stuey,
my only note here is the following:
the type of configuration you have implemented on Router G is supported for migration purposes: up to three net are supported to make easier the process of migration from a CLNS address plan involving area1 to another address plan involving area2.
CLNS just needs one address /net for a node whatever is the number of physical interfaces running CLNS, IPv4 and IPv6 uses one or more prefixes for each L3 interface.
This is a big difference and makes the results of sh clns route different and sometimes difficult to be read.
Notice that for an area of which a node is a member of you can get a list of IS intermediate systems connected to the area and known via the flooding of their respective LSPs.
In the case you show the router is probably telling in its own way that to reach the other area it needs some form of recursion through the area it is a member of.
A different scenario is when you use multiple IS-IS processes and each has its own net.
see
http://www.cisco.com/en/US/docs/ios/isoclns/configuration/guide/configure_iso_clns_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1071447
Hope to help
Giuseppe
