disable ssid or dot11radio when no lan connection
Answered Question
Apr 3rd, 2009
I have a configuration where I need an access point(1131ag) to disable the dot11radio interface or or disable the ssid when the fastethernet0 interface is down. Is there an option for this?
Dan.
Correct Answer by mprofitt1967 about 8 years 3 weeks ago
(config-if)#station-role root access-point fallback shutdown
Overall Rating: 5 (1 ratings)
Scott Fella Fri, 04/03/2009 - 20:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I'm pretty sure this is not possible. Do you have issues with the switch port always going down and users associated to that ap hanging in limbo? If it was a PoE switchport, I would think that power to the ap would bring down the ap.
danletkeman Fri, 04/03/2009 - 20:18
This ap is on a cart with notebooks. The cart is brought to a room, the ap is then plugged into to the wall jack and then powered on. The notebooks are then used in that room. The problem is that when the person that brings the cart into the room forgets to plug in the network cable, or the wall jack is not live/working the ap broadcasts, but nobody can connect.
Dan.
Correct Answer
mprofitt1967 Fri, 04/03/2009 - 21:48
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
