FWSM Software Upgrade
Apr 3rd, 2009
Just want to ask on how to upgrade software from 3.0 to 4.0
gmarogi Thu, 04/09/2009 - 06:19
You can upgrade both the application software and the maintenance software. To upgrade the application software
To upgrade the maintenance software
The entire application and maintenance partitions are stored on the FTP or TFTP server. The images are downloaded and extracted to the application or maintenance partition depending on which image is being upgraded.
To upgrade the application partition, change the boot sequence to boot the module from the maintenance partition. The maintenance partition downloads and installs the application image. The supervisor engine must be executing the run-time image to provide network access to the maintenance partition.
