inside to outside traffiic times outs
Apr 3rd, 2009
Seem to be having an issue with a firewall I've inherited asa5520
some http downloads seem to be timing out, as well as some websites. When I bypass the ASA no problem.
also have a couple statements and I'm not sure as to why?
outside a.a.a.a
inside b.b.b.b
dmz c.c.c.c
dmz2 d.d.d.d
global (outside) 1 a.a.a.3-a.a.a.98 netmask
global (outside) 1 a.a.a.100-a.a.a.200 netmask
global (DMZ) 1 c.c.c.80-c.c.c.250 netmask
nat (inside) 1 dns
nat (DMZ) 1 c.c.c.0 dns
static (inside,outside) tcp interface 2300 b.b.b.32 2300 netmask
static (DMZ,outside) a.a.a.252 c.c.c.1 netmask
static (DMZ,outside) a.a.a.240 c.c.c.3 netmask dns
static (DMZ,outside) a.a.a.243 c.c.c.8 netmask
static (DMZ,outside) Mail IronPort_DMZ netmask
static (inside,outside) a.a.a.247 b.b.b.74 netmask
static (inside,outside) c.c.c.c b.b.b.b netmask
static (inside,outside) a.a.a.99 b.b.b.98 netmask
static (inside,DMZ) b.0.0.0 b.0.0.0 netmask
static (inside,DMZ2) b.0.0.0 b.0.0.0 netmask
access-group acl_out in interface outside
access-group acl_dmz in interface DMZ
access-group DMZ2_access_in in interface DMZ2
route outside a.a.a.1 1
route DMZ2 d.d.d.0 e.e.e.253 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:b:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:b:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
Anonymous (not verified) Thu, 04/09/2009 - 05:56
You may try changing the uauth timeout. As a trial you may change it to "timeout uauth 01:00:00" and then try downloading. Also you may try removing the inline IPS.
