drolemc Thu, 04/09/2009 - 18:11
  • Silver, 250 points or more
The 2811 do not support NM-1E1R or NM-2E. Ensure your Network module will support or not. Romove the Nm module And switch off the router then insert the module. Once you installed the restart the module and configure newly then try.
paolo bevilacqua Thu, 04/09/2009 - 18:55
  • Hall of Fame,
    Founding Member
NM "what ?".
You've only sent show config.
Please describe the problem properly.
Leo Laohoo Thu, 04/09/2009 - 19:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I'll agree with the 2 post before me. What network modules did install? Aside from the NM-1E, I think you also put a NM-4T too.
The link below will tell you what modules you can install into your appliance. Good luck.
http://www.cisco.com/en/US/products/ps5854/products_data_sheets_list.html
