Monitor nuber of VPDN sessions on PRTG
Apr 4th, 2009
Hi all
I have a 7204VXR router on which PPPoE users connects,
I want to monitor on PRTG(or any software that you recommend) how many sessions are opened.
I used the OID stated in another post "1.3.6.1.4.1.9.9.194.1.1.1." and I GET in the TEST OID: Error Converting OID
I tried to remove the last dot, so i entered "1.3.6.1.4.1.9.9.194.1.1.1" and when i did the TEST OID, i got a zero in the end "1.3.6.1.4.1.9.9.194.1.1.1.0"
and the Value of the OID is always 0
I tried also another MIB that is saw on cisco MIB locator(in the attached picture) and didn't work either
mchin345 Thu, 04/09/2009 - 13:05
  • Silver, 250 points or more
I think Cisco View can able to monitor the VPDN Session.
Try tbelow command also.
Displays VPDN session information including interface, tunnel, username, packets, status, and window statistics.
Router# show vpdn session [all [interface | tunnel | username] | packets | sequence | state | timers | window]
