Apr 4th, 2009
I configured ISDN like following.
Router 1.
Loopback 0
ip address
interface Dialer7
ip unnumbered Loopback0
encapsulation ppp
dialer pool 1
dialer idle-timeout 30
dialer caller 233****890
dialer-group 1
no cdp enable
ppp authentication chap
Router 2.
interface BRI0/0/0
ip address
encapsulation ppp
dialer string 0206****900
dialer-group 1
isdn switch-type basic-net3
isdn point-to-point-setup
isdn caller 206****900
I configured dialer list and username all the thigs.But isdn layer I status shows deactivate.
Debug report...
Apr 4 13:14:50.329: ISDN BR0/0/0 **ERROR**: host_disconnect_ack: Unfound B-chan
nel on Disconnect_Ack call id 0x8013
Apr 4 13:15:12.325: ISDN BR0/0/0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id
0x8013, event 0x5 ces 1
Thanx in advance.....
lamav Sat, 04/04/2009 - 06:14
Not sure if this is the problem, but I believe that you should have PPP Multilink configued under the BRI interfaces. This is what enables the ISDN caller to utilize both B channels.
Richard Burts Sat, 04/04/2009 - 14:36
While Victor's advice about multilink may be good advice, your problem is at a lower level that this. If the status is showing as disconnected then you are not communicating properly with the ISDN switch.
I have sometimes seen problems associated with use of isdn point-to-point setup. if there is not a particular reason to have it configured I would suggest that you remove it.
Can you verify that the interface is correctly connected and that the switch type you have configured is the proper switch type?
arjunsawant Wed, 04/08/2009 - 23:10
I configured PPP Multilink on both side. but still problem persist.
Pls see the logs.. when i fire isdn ..
Richard Burts Thu, 04/09/2009 - 12:52
This debug output is significantly different from the debug output in the original post. Is this debug from the same machine as the first debug or is it perhaps from the other router?
If it is from the same machine have you made changes other than configuring multilink? If so what were the changes?
Can you post the output of show isdn status from both machines?
lamav Thu, 04/09/2009 - 17:20
From the disconnect code:
Cause i = 0x8283 - No route to destination
It is telling you that the local telco switch had inititated the disconnect and the reason is that the dialed number is not reachable.
Is this number valid?
When I dial it from my house, I get a message that says "this number cannot be completed as dialed...check the number..."
