AutoQOS with non Cisco VOIP solution
Apr 4th, 2009
Hi All,
Can I deploy AutoQOS on my LAN switching and layer 3 switching when using a Siemens VOIP solution. I realise that their phones do not do CDP, so I need to trust the COS on the access port. But can I use all the other AutoQOS settings?
Thanks in advance for your feedback.
Scotty
bmcginn Sun, 04/05/2009 - 20:03
  • Bronze, 100 points or more
Hi Scotty,
Assuming the phones mark the voice packets to the same markings as the cisco phones do (usually EF), and the signalling traffic to the same as the cisco phones (CS3 i think), and the trust boundary is moved to trust the phones, then you should be good to go.
You just have to make sure that the PC that is connected to that port (if the PC connects to the phone, and the phone to the switch for example) has its packets marked to zero as appropriate. You don't want a situation where some smart user's mark their PC's traffic as EF, and your switch trusts it..
Brad
