c805 no tacacs-server key command
Apr 4th, 2009
System image file is "flash:c805-y6-mw_120-4_XM"
Cisco C805 (MPC860) processor (revision 0) with 46944K bytes of virtual memory.
Processor board ID JAD051808LA
CPU part number 33
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
8M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
8M bytes of flash on board (4M from flash card)
V_Bb(config)#tacacs-server ?
attempts
directed-request
extended
host
last-resort
optional-password
retransmit
timeout
Where is the "key" command? My server wants it.
Or my image doesn't support full TACACS+?
TIA,
sahmedshahcsd Sat, 04/04/2009 - 23:57
Try configuring one line command as this "tacacs-server host hostname key XXXX" and see if it works.
However it is also indicated that Cisco 805 router in Cisco IOS Release 12.0(4)XM1 does not support AAA Radius and AAA Tacacs+ for more information please refer to the following link http://www.cisco.com/en/US/docs/ios/12_0/12_0xm/release/notes/rn800xm.html#wp15395
Ahmed
aruzsinszky Sun, 04/05/2009 - 01:59
I think I tried it without success.
So my only solution is the upgrade?
TIA,
