How I can know how many CAD agents licenses do I have?
webstd.design
I use IPCCE 7.2
8 Replies 8
in the cad server you'll find an executable with the word license on it.
david
ShowLicenceUsage.exe in Program Files\Cisco\Desktop\bin. It displays the agent ID and the IP address of the box they are logged in from.
I feed it into the Unix-like word counter that comes with the Cygnus tools (wc -l counts lines) and subtract 5, thus getting a count.
When you have a lot of agents, you need a tool.
Be aware that this is not quite the "logged in" count. When a CAD is running, it uses a licence, independently of whether the agent is actually logged in.
Geoff
But this utility ShowLicenceUsage.exe displays only active agents.
Here isn't info about available licenses?
Yes, it shows how many agents are using a licence.
Don't you know how many licences you have?
Can you run LicenceManager.exe and see how many you have? If this doesn't show it, try hitting the Spanlink web site again and putting in the customer ID.
Geoff
I didn't find any LicenceManager.exe or LicenseManager.exe file on ICM.
Check in Program Files\Cisco\Desktop\bin on your CAD machine (as David says, probably your AgentPG).
Geoff
What do you mean about typing try hitting the Spanlink web site again and putting in the customer ID.
Can you exaplin in more detail this waY?
Did you check the CAD server? Usually the PG. Also, do you have a customer ID # from your order? If so you can go to the spanlink website and check your order.
david
