h.323 g/w - inbound name display
Apr 4th, 2009
I've been trying to get name display on inbound calls. CCM 4.1.3 with a 2851. I've tried with both 12.4(24)T and 12.4(11)XW10.
I've added the following configs from googling and cisco.com searches:
voice service voip
h323
h225 timeout ntf 300
h225 display-ie ccm-compatible
voice class h323 1
interface Serial0/0/0:23
isdn supp-service name calling
I've tried both with and without the "h225 timeout ntf 300" statement as I didn't see the 'name follows' message in the q931 debugs. The isdn q931 debug does show the callid name in the facility message though, but a h225 debug q931 doesn't show it in the display ie field. ...which means I'm not getting it to the phone either.
Any ideas will be much appreciated.
thanks,
Will
gogasca Sun, 04/05/2009 - 15:51
Hi Will,
Can you please upload the following:
debug isdn q931
debug cch323 h225
debug h225 asn1
debug voice ccapi inout
and your sh run.
thanks
will.alvord Mon, 04/06/2009 - 11:01
I've attached the debug output of a test call and sh run output.
In the isdn q931 debug output, I can see the company name (which I've doctor'd a bit):
-------------------8<--------------------
001145: Apr 6 18:39:22.750: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x02C4
Facility i = 0x9F8B0100A112020101020100800A4F5552434F4D50414E59
------------------->8--------------------
There are a several leading bytes which I don't understand, but beginning with 4F5552 is the ascii code for "OURCOMPANY".
Just noticed that you asked for a debug that I didn't run (cch323 h225). I had just run the following ones requested by TAC:
debug isdn q931
debug h225 asn1
debug h225 q931
debug h245 asn1
Hopefully that will be enough for you to isolate the problem.
thanks,
Will
smithn_14 Wed, 04/15/2009 - 05:27
Have you got any response or a solution on this? We are expereicing the same issue.
will.alvord Wed, 04/15/2009 - 06:15
TAC advised me to change the switch type to primary-ni (ni2). I had a confusing call with an engineer with our carrier who stated that their switch type is 5ess but that I should use NI2 in order for the name display to work.
I'm a little fuzzy on how that could work. It was my understanding that the dchannel wouldn't come up if the switch types mismat. This engineer told me that there should be a different field/command to enter NI2 as a protocol rather than a switch type. I think he's confused, but he also confused me.
So bottom line is that TAC and my carrier are telling me to change the switch type to primary-ni. The Cisco docs state that the router will need to be restarted for that change. I have an opportunity to do that on saturday so I'll give it a shot and let you know.
If anyone has any docs or links explaining how a PRI connecting to a 5ess (or other) switch would work with an ISR with "isdn switch-type primary-ni" configured...I'd love to read them.
thanks,
Will
Nicholas Matthews Wed, 04/15/2009 - 07:02
Hi Will,
I think what may be confusing is that the different switch types are surprisingly similar. Most of the basic call features will work with switch type mismatches. This is a very common problem. Sometimes providers are not sure what their switch type maps to on Cisco, and there is confusion for everyone.
If it works with NI2, I would run with it. I think you can probably just shut/no shut the T1 controller, change the switch type, and save yourself a reload.
Most of the switch type mismatch problem symptoms are things like strange characters showing up at the beginning of caller ID, calling name not showing at all, receiving status message that have 'invalid IE contents', and supplementary features like transfers or specific IE contents not matching up correctly.
I'd go with TAC on this one.
-nick
will.alvord Wed, 04/15/2009 - 07:07
Cool. I've got the change scheduled for sat morning. I'll let you know how it goes.
thanks,
Will
will.alvord Mon, 04/20/2009 - 07:46
Good deal. Changed the switch type to primary-ni, shut & no shut and am getting name display now. Some calls (looks like calls from cells) are only displaying the name though -- which makes it impossible to dial from missed/received directories.
Any ideas on that?
thanks,
Will
will.alvord Mon, 04/20/2009 - 09:24
Sure thing.
voice service voip
fax protocol none
h323
no h225 timeout keepalive
call preserve limit-media-detection
modem passthrough nse codec g711ulaw
no ip address
encapsulation hdlc
no logging event link-status
isdn incoming-voice voice
isdn map address ^011.* plan unknown type unknown
no cdp enable
thanks,
Will
