Resetting and management of Catalyst 2948G
Apr 4th, 2009
I just recently picked up a Catalyst 2948G and would like to find out the following: 1/ how to reset the unit, and 2/ find out if it is possible to manage the unit through CISCO's Network assistant as i am unfamikiar with the CISCO terminal access. I would truly appreciate some assistance regarding this matter.
glen.grant Sun, 04/05/2009 - 09:08
CNA only supports IOS switches that is an older catos box. The only way to reset it is thru command line . The "clear config all" command will reset it. If you get the right catos version on it , it can support a gui interface.The image version would have to a "cv" somewhere in the image name which stands for ciscoview.
