ASA CSC-SSM - Drop Rate Exceeded
Apr 4th, 2009
On ASA 5520 with CSC-SSM, I am getting the below log message. What does it mean ?
4|Apr 05 2009 09:45:52|733100: [ Scanning] drop rate-1 exceeded. Current burst rate is 10 per second, max configured rate is 10; Current average rate is 13 per second, max configured rate is 5; Cumulative total count is 8155
htarra Thu, 04/09/2009 - 15:14
Recommended Action:
Perform these steps according to the specified object type that appears in the message:
1.
If the object in the syslog message is one of these:
Firewall
Bad pkts
Rate limit
DoS attack
ACL drop
Conn limit
ICMP attk
Scanning
SYN attck
Inspect
Interface
Check whether the drop rate is acceptable for the running environment.
2.
Adjust the threshold rate of the particular drop to an appropriate value by running the threat-detection rate xxx command, where xxx is one of these:
acl-drop
bad-packet-drop
conn-limit-drop
dos-drop
fw-drop
icmp-drop
inspect-drop
interface-drop
scanning-threat
syn-attack
3.
If the object in the syslog message is a TCP or UDP port, an IP protocol, or a host drop, check whether the drop rate is acceptable for the running environment.
4.
Adjust the threshold rate of the particular drop to an appropriate value by running the threat-detection rate bad-packet-drop command. Refer to the Configuring Basic Threat Detection section of the ASA 8.0 Configuration Guide for more information.
