ipma
Apr 5th, 2009
hi,
i have been configuring ipma with proxy line on cm 4.1(3), i have two questions
1-the service url should it point to the pub or the sub
2- when configuring the service parameters, do i put the sub or the pub as the primary server
Jaime Valencia Sun, 04/05/2009 - 14:26
  • Cisco Employee,
  • Hall of Fame,
    2011
the recommendation is to use the call processing server that your phone uses
most usually you'll point to sub
java
if this helps, please rate
