ASA Renewal Question
Apr 5th, 2009
I have ASA-SSM-CSC-20
with 1000 user license and Plus license
I wan to renew it with 250 user only.
Is it possible?
Or Do I need to buy new license?
b.speltz Fri, 04/10/2009 - 06:20
Yes, I think this is possible. I'd contact your local sales office. They should be able to set you up.
sachinga.hcl Sun, 04/12/2009 - 18:13
Hi Dear,
Do you have a PAK number?
Go to, enter the PAK and follow instructions. You will receive an email with new activation key. Then login to ASA and do
Best Regards,
