CUPC unable to log in
Apr 5th, 2009
  • Blue, 1500 points or more
When logging into CUPC: "Login failed. Make sure your username and password are correct"
Login server=<ip addr. presence server>
We run:
CUPS 7.0 in conjunction with CUCM 6.1.3
CUPC 7.0
I have assigned a number of users to the CUPS cluster, and have added a number of CUPC's to Call Manager (Device name= UPC<USERID).
-CUPC device is associated with userID in CUCM
-primary extension is chosen
-Capabilities are assigned
-Authentication in CUCM uses LDAP.
-CUPS diagnostics shows all service are running, and sync-ed with CUCM.
any ideas?
Rajesh Revuru Sun, 04/05/2009 - 16:42
  • Silver, 250 points or more
Check if the users in CUPS are assigned to publisher node under Topology
htluo Mon, 04/06/2009 - 06:17
  • Red, 2250 points or more
Try this:
1) Go to CUPS command line
2) Type the command below:
utils serivce restart Cisco Tomcat
Thanks!
Michael
http://htluo.blogspot.com
Dennis Mink Mon, 04/06/2009 - 22:37
Thanks Mike,
that seemed to have done the trick
