Re: 6500 MSFC3/PFC3 and service-policy output command ...
Answered Question
Apr 5th, 2009
I have a 6500 box with MSFC3/PFC3 and have upgraded the IOS version to s72033-advipservicesk9_wan-mz.122-18.SXF11.bin. It was running IOS verison before this : s72033-pk9sv-mz.122-17d.SXB11.bin
It does note seem to accept the service-policy output command after the upgrade.
routerA(config)#int gi2/47
routerA(config-if)#service-policy output A-Voice
bandwidth percent command is not supported in output direction for this interface
Configuration failed on: GigabitEthernet2/47
routerA(config-if)#service-policy output A-Voice-100M
bandwidth command is not supported in output direction for this interface
Is MQC with the bandwidth or bandwidth percent command not supported on the 6500 series box ?
Pls advice,
Cheers,
- InternetB -
Correct Answer by Edison Ortiz about 7 years 10 months ago
It's not supported when using regular line cards along with the PFC QoS.
If you purchase a SIP/SPA module, then you can use your regular MQC commands.
Please refer to the documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1465326
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Mon, 04/06/2009 - 06:13
HTH,
__
Edison.
