PBR Features
Apr 5th, 2009
Hi All,
I am currently testing the PBR feature and i would like to know how it functions.
the scenario is the following:
we would like to redirect the traffic to SWITCH2 when the destination is an IP from the subnet 10.160.130.0.
i am doing the test from switch 1 by doing an extended traceroute.
the source IP is SVI 990 10.160.123.145.
the test fails, i am still able to reach the directly connected server on switch1. any explanation ?
the configuration and a network diagram that illustrates the scenario are attached.
thank you.
Jean
thotsaphon Mon, 04/06/2009 - 00:06
Jean,
First of all, Router generating traffic will not work. You have to use "ip local policy route-map".
A defined route-map named "PBR_Route_Map_Testing". At the interface level I saw "PBR_Route_Map". Typo?
I would test by using other hosts in network,10.160.123.0/24.
HTH,
Toshi
jeansamarani Mon, 04/06/2009 - 00:53
Hi Toshi,
yes it's a type so i need to use the local policy route-map in case i need to test the PBR from the router itself?
thanks
